How much power from my injectors??
Avinitlarge
Post by Avinitlarge »
PSIG wrote:What brand and model RRFPR are you using? Most RRFPR's can either be set or internal parts swapped to allow for normal 1:1 rate. A quick call to the manufacturer should get you the answers you need.
David
The one I have fitted at the momment is a Sheepdog VRS
Megasquirt V2.2 main board
MegaTune 2.25
Extra029T
Innovate LC-1 Wideband Lambda
http://WWW.MONDEOTURBO.COM
Avinitlarge
Just found out that the FSE one is a 1:1.7
MegaTune 2.25
Extra029T
disc
Post by disc »
Avinitlarge,
From what car comes that 440 cc/min injectors? I hope they fit in Zetec fuel rail 8)
You can use CVH EFI/EFI turbo FPR, as they are the same and they are Weber made, also adjustable.
Avinitlarge
disc wrote:Avinitlarge,
I have a set off 370cc and a set of 440cc injectors for sale. £50 for the 370cc and £100 for the 440cc
Plus postage costs
MegaTune 2.25
Extra029T
disc
Post by disc »
Avinitlarge,
I have 370 cc/min too (same like yours), but my question was - yours 440 cc/min from what car they come from?
P.S. I suppose they come from some Japan car?!?
disc
Post by disc »
Avinitlarge, From what car comes that 440 cc/min injectors? I hope they fit in Zetec fuel rail Image You can use CVH EFI/EFI turbo FPR, as they are the same and they are Weber made, also adjustable.
Ford Zetec Turbo in progress... MSnS-E, EDIS4, LC-1 ect. The engine is now in the car Image MS-ed, Turbo-ed, EDIS-ed Lada 1600 cc
-------------------- m2f -------------------- This post is at: http://www.msefi.com/viewtopic.php?p=135612#135612 -------------------- m2f --------------------
Posted by email.
