MS2 V2.5 Wheel Decoder Code Update?
jsmcortina
- MegaSquirt Guru
James
The posts were moved to the hi-tech forum (http://www.msefi.com/viewtopic.php?t=15779) since they dealt with "technical developments not currently implemented in MegaSquirt/MS-II".
Kevin Wood
Was just scratching my head trying to work out where I'd posted. Could
have sworn it was on this thread ;-)
Kevin
Posted by email.
barf
i get the following error when compiling (with gcc in linux)
the called function that causes the error is:main.c: In function `Flash_Erase_Sector':
main.c:4994: error: parse error before '{' token
main.c:4995: error: syntax error at '#' token
main.c: In function `Flash_Write_Word':
main.c:5006: error: parse error before '{' token
main.c:5007: error: syntax error at '#' token
make: *** [main.o] Error 1
Code: Select all
asm {
ldaa #CBEIF
jsr RamBurnPgm
return;
BraneDeadx
Sean..
All the new features in v2.5x and 2.6 are spelled out in the state of the union message under the General Megasquirt forum.BraneDeadx wrote:I had quick question, with the 2.53 code and 2.34 code, is there any other differences besides the wheel decodeing portion? or was that the main high light of the newer code
Sean..
