tomf757if the fuel pump circuit is blown does this affect the cpu in any way shape or form?
No, the fuel pump circuit doies not affect the CPU at all.
The flyback failure should not affect the fuel pump circuit (the most common cause of the fuel pump circuit dying is the voltage being reversed, even momentarily, and can result from the stim or vehicle power being hooked up backwards (usually), or from negative spikes in your voltage supply (much less often). Replacing the fuel pump transistor usually fixes it.
