Page 11 of 12
Re: More Data
Posted: Wed Dec 23, 2009 3:23 pm
by TheMonkey
Peter-
Car is in the barn for the Winter now, but if there are any questions in particular, I'll answer them however I can.
On this car, I swapped from the original '80 distributor to the D585s. Difference was big in responsiveness, but perhaps that had to do with mapping also (even though I tried different amounts of advance in distributor).
The original ignition was very particular about plug gap. I was able to gap up quite a bit, which seemed to help MPG and idle quality. See the MyE28 post on this: http://www.mye28.com/viewtopic.php?t=66269
I think there is also some info in the uS beta forums when I first had D585 coils on my Pontiac. I initially wired them with the small gauge signal wires backwards and learned that GM LS coils have two different wiring schemes. Be careful... with the D585 (LS truck), they are different from the other LS coils without heat sink on it, even though the pigtail looks the same.
Are you looking to put these on your car?
Scott.
Re: More Data
Posted: Wed Dec 23, 2009 3:28 pm
by Peter Florance
Scott.
Or something similar. I'm really wondering about the mounting and whether you used wires or solid boots
Thanks!
Re: More Data
Posted: Wed Dec 23, 2009 3:48 pm
by TheMonkey
The wires, I haven't found a good solution yet. For this car, I cut the original Bosch distributor wires since the hard boot to plug was particular for this car (deep into head). I think I have part numbers for the coil end, but the boots are too small, although they work. I got the terminal and boot kit from Taylor wire via Summit. I haven't found proper boot kit for these coils yet. Best bet is probably to get some LS wire kit, and hack into the plug end if necessary to change it.
If you find a boot kit to fit these coils, let me know!
Mounting was sort of a hack with a strip of aluminum angle iron, and spacing the coils off a bit for clearance.
For my Pontiac, I drew up a bracket to have laser cut, but I might end up with the same aluminum angle for that car too to keep up the strength.
Re: More Data
Posted: Thu Dec 24, 2009 3:55 am
by Peter Florance
TheMonkey wrote: If you find a boot kit to fit these coils, let me know!
Thanks Scott
Do you think anything at Kingsborne would be useful?
http://www.kingsbornewires.com/category ... egoryId=83
Re: More Data
Posted: Tue Dec 29, 2009 10:42 am
by TheMonkey
Peter-
That looks like a good source. They would certainly know the issues.
I think the Taylor boots I used were called LT1. The important thing is that the metal clip is the right shape to attach to the coil. Then, the problem I ran into was finding the right size boot to go over the coil housing. The LT1 boots were a bit to small and tend to 'poo' off the coil if you put in dielectric grease. Holds okay if dry, but obviously a trade-off.
Scott.
Re: More Data
Posted: Tue Dec 29, 2009 11:01 am
by Peter Florance
TheMonkey wrote:Peter-
Scott.
Hi Scott
Thanks for that. I wonder if I could just buy an LS1 wire set and shorten it with connectors to fit my plugs?
Re: More Data
Posted: Tue Dec 29, 2009 11:41 am
by TheMonkey
Peter Florance wrote:..... I wonder if I could just buy an LS1 wire set and shorten it with connectors to fit my plugs?
Yes, I reckon so. On the BMW, I didn't do that because I needed the deep hard plastic plug connectors to go into the head, and I also just kind of took the easy route.
Re: More Data
Posted: Wed Dec 30, 2009 12:36 am
by Joe
This is the setup I'm using (Had trouble with attachent on other post)
Joe
Re: More Data
Posted: Sun Jan 03, 2010 3:41 pm
by TheMonkey
Good info Joe. Very nice looking setup.
Re: More Data
Posted: Sun Jan 03, 2010 4:31 pm
by Peter Florance
Thanks for all the input!
