Fast idle valve suggestions?
russ
Post by russ »
hehe, thats funny! my next question was gonna be- can i use the idle stabiliser valve in my coupe gt as a fast idle valve? sorted then.
could you explain what the risistor is all about though, and what type i should use?
Cheers,
Russ.
philhoward
Post by philhoward »
If you can find a Bosch K-Jetronic powered motor (80's VW/Audi?) then the Bimetallic variable unit as shown in the Megamanual works fine on mine - no need to use the FIDLE wire (leaving it spare for MSnS...)
Working on a 2.0 Zetec turbo engine..slowly!
mike_wiz
Bosch air Regulator
Post by mike_wiz »
I found one of these at JY yesterday and just want some clarification and advise. I am going to be running this on a 360 Dodge Magnum Crate.
This looks like the easiest way to go for Fidle control. This is mainly used for driving to trails and rockcrawling all day. ( No Turbo or anything just straight up driving)
I imagine I will try to bolt it to the intake manifold somehow. This should ne fine right? Thanks.
