ok, i will work on getting that info along with pics of my set up, thanksLance wrote:turbomax,
You problem could be anything from incorrect sensor spacing to the teeth to induced noise in the wiring to the wrong setup in the code for your setup.
To narrow it down, it would help if you posted your hardware version (presumably a microsquirt, but V2 or V3?), code version, MSQ (settings file), a datalog of the problem (so we can see the problem as well as the diagnostic parameters), and a thorough description of your trigger wheel, sensor(s), wiring, and engine configuration.
Yamaha pickup coils
Re: Yamaha pickup coils
micro squirt v3
- Attachments
- 2016-01-17_c-10 tune.msq
- current tune setting (could be all wrong from trying things)
- (31.49 KiB) Downloaded 313 times
- 2016-01-17_16.39.42.msl
- cranking over log
- (50.17 KiB) Downloaded 316 times
Looking at the image of your tone wheel, I'm suspicious it isn't uniformly shaped. Regardless, one excellent way to flush out problems is to set up your Microsquirt on a test bench with a Jim Stim, and then test your triggering components & settings in a drill press or variable hand drill. You can pickup a Cheap ATV sprocket with say 36 teeth, remove one tooth for original 36/1 format and check your behaviour in the tooth logging menu of Tuner Studio. That way you can see proper function, how fast it has to spin, and any other issues or wrong settings. Then transition functioning stuff back onto perhaps a smaller diameter tone wheel and if it works too, then back to the bike. I did this when I upgraded to sequential ignition and had issues with cranking speed on my single toothed cam sensor (& 36/1 crank wheel). The addition of EFI Analytics little "VR Conditioner" chip now allows sync down as low as about 17rpm.
Good luck.
