Firmware Upgrade broke AFR
McMark
Re: Firmware Upgrade broke AFR
Post by McMark »
Setting the cranking RPM does work. Was 350rpm, I changed to 300, powercycled and checked - it said 300 rpm.
I deleted the log file, started TS (checked that it was the newest version) and tried to write the CLT calibration once. Then quit TS.
Looking at the log line by line, the first thing I notice is the Warning: CRC Mismatch!!!!, but I don't know what that is...
Code: Select all
9/9/13 5:37:29 PM :Info: Going Online with ** V3.83Embedded Code by B&G **
9/9/13 5:37:29 PM :Debug: Reading ECU Data, 0.0 complete
9/9/13 5:37:29 PM :Warning: CRC Mismatch!!!!
9/9/13 5:37:29 PM :Debug:    CRC from controller page 1:xE2 xA2 x29 xA7                                                       ..).
9/9/13 5:37:29 PM :Debug:    Local Data CRC for page 1: xB9 x0D xCF x56                                                       ...V
9/9/13 5:37:29 PM :Debug: Read page time: 94ms.
9/9/13 5:37:29 PM :Info: Checksum of data read: xE2 xA2 x29 xA7                                                       ..).
9/9/13 5:37:29 PM :Debug: Reading ECU Data, 0.5 complete
9/9/13 5:37:29 PM :Debug:    CRC from controller page 2:xAE x4A x92 x48                                                       .J.H
McMark
Post by McMark »
Finally saw the big bold warning saying that 3.83 must use the beta version of TunerStudio. :oops: Everything works with that version. Sorry for having wasted your time. :( :cry:
No problem - glad it works now.
