Wiring in relays for fan/water injection control etc.
Re: Wiring in relays for fan/water injection control etc.
anonymous.shyster
anonymous.shyster
I've just checked the standard output port options. The programmable ports can be turned on or off depending on the value of some internal variable relative to a set point - ie, ON if CLT > 190F (useful for a rad fan). There is no option to compare two internal variables, and certainly no option to compare the differential between two variables.
Since you're adding two temperature sensors anyway (intercooler coolant and ambient air temp), run them to a comparator. Assuming they both have the same voltage / resistance per degree and are fed from the same Vref (which could be raw 12v, depending on the model of comparator you select), a simple pot would be enough to dial in your delta-T. Wire the top of the relay coil to +12v, wire the coil outlet to the comparator 'outlet' (we're talking less than 60mA, remember), and call it soup!
anonymous.shyster
So, what is comparator? How do I choose one that is right?
anonymous.shyster
Here's a pretty good page on how to use these devices - http://home.cogeco.ca/~rpaisley4/Comparators.html
anonymous.shyster
I am putting EFI on a 79 Goldwing, I might try your board.
