[SOLVED] Tach input OK but IGN1 not firing /
Re: Tach input OK but IGN1 not firing,
So on the advice of dontz, i changed the position of IGN1 jumper, to put it in the same position as IGN2 : still nothing on my spark plugs.
@grippo : i removed my "Offset for output 2" , you are right, it's already taken care of by the "Skip teeth" feature.
But again, still no spark on IGN1.
My coils are good, my spark plugs are good (i tested them by putting em on IGN2 and they fire). I swaped the "+", and then the "-" but still the same thing.
Do you guys think something could be fried ? If so, how could i test it ?
Thanks fellows
I will be able to work on the engine only sunday, so i would apreciate a lot if i had some leads to invest when i can have access to the engine !
Thanks guys
Can you make a datalog and post this and the msq you used to make the datalog, that is, at the end of the datalog do a File save to get the msq that is in the engine.
I will make a datalog asap.
- Attachments
- datalog_2011-10-05_14.34.06.msl
- (71.95 KiB) Downloaded 56 times
- slingy88_cfg_2011-10-05_15.02.02.msq
- (25.96 KiB) Downloaded 59 times
Re: Tach input OK but IGN1 not firing // new datalog + msq
http://www.youtube.com/watch?v=F6XCcsmQDi0
I just tested the controler with my scope, and clearly it appears that nothing arrives to the driver on IGN1. On IGN2 I could see the signal on my screen, nothing on IGN1. So I guess the processor is in fault here.
