skewed sensor readings
tiff
Re: skewed sensor readings
Post by tiff »
hi i made a data log showing my rpm signal dropping out . my signal comes out of my ignition module on to pin 30 optin+. then i changed it to my coil negative and datalogged that [worse]. then i changed it back to ignition module tach lead now i dont get a rpm signal in tunerstudio at all. i disconnected the ecu and checked at the ampseal connector with my multimeter and the signal is there cranking??? any thoughts???
2009-06-27_16.41.06.msl
(465.45 KiB) Downloaded 30 times
2009-06-27_18.03.31.msl
(120.19 KiB) Downloaded 29 times
