Sequencer First attempt in car
ca434sbc4
Re: Sequencer First attempt in car
-I found some 1F caps for a reasonable price - should be here Wed.
-Wired the injectors up to the sequencer - without a external prime its too lean and won't fire. Even with an external prime its so lean the engine dies after a few seconds. Currently its set for 2 point cranking pulse widths, I'll change over to the table set up and crank the pulse widths up until it starts.
- I need to finish wiring in the TPS and IAT sensors, currently the IAT and TPS signals are tied to signal gnd. The IAT will try and lean the mixture out when connected to gnd. as it thinks the air is hot.
Another round tomorrow evening time permitting.
- Attachments
- fuel enabled.msl
- (359.97 KiB) Downloaded 45 times
- megasquirt200903222036.msq
- (25.45 KiB) Downloaded 47 times
i am not getting a good reading on my tach. brand new autometer. i made sure toggles were set for V8. i'll take a closer peek at the signal on the scope to see what the signal looks like. my scope will get data points as low as 5 microseconds if only using one channel, so i can see this signal close, but can't see too much detail on a 15 microsecond pulse.TheMonkey wrote:...
I've been out of town, but I'll try my tach signal to my tach before I pull the temp wiring for final wiring and splicing.
at first it was just reading a fractional RPM (600 when motor was 1000), then next try it just flinched when turned on and didn't show any RPM.
why is the pulse so short? it's not possible to have an adjustable pulsewidth?
yeah, this tach worked fine with MS2 using MSD box tach output.krisr wrote:My Autometer tacho has always worked flawlessly when being wired up to the various CDI units i've used...
you're right Al- no need to scope it. i've seen it before, i know it occurs every pulse, and i know it's very short.
- Site Admin
Anyway, Al will lengthen it. Now.. it'll be too long and high RPMs will not register because the duty cycle will exceed 100%...
RedRocketRally
The instructions for my autometer gauge say to connect to the negative side of the coil or to the tach terminal of an electronic ignition. maybe the sensing circuit is expecting short ground pulses (that's how a coil would look, right?) and needs 12V for longer to charge (something?) back up to wait for the next pulse? Maybe it rejects short 12V pulses for noise reduction?
Just guessing, but if 150usec should be long enough, could we get a test version with the polarity flipped? That should just involve swapping the &'s and |'s in the code and won't affect any timing, right?
the length of my pulse is between 96 - 101 microseconds (scope grabs 5 microsecond datapoints). the voltage was kind of weird; between 8.5v & 10.8v.
BUT... there's a hanging chad.... my wiring is still messy and susceptible to RFI.
If you wanted to test an inverted signal, you could just put it through a transistor on a perf board. A 555 timer could also be used to lengthen the pulse to say 1 ms.
