Page 2 of 2
Posted: Fri Mar 21, 2008 3:54 am
by pommie02
Sounds good to me Ian...are you going to the AFR. with Dave?
I have still got a bit to do with the fitting of the system..Ill pm you when Iam ready.....thanks Gary
Posted: Fri Mar 21, 2008 11:53 pm
by newtyres1
Yes, I'm going with Dave. Good luck in the meantime with the install. Between you, me and Dave we should be able to get the PC side sorted out pretty quickly. If you wait a couple of days, the Megatune download files should be fixed, if they aren't already, that might sort your issues very quickly with any luck. After you uninstall your current Megatune, and before loading the new one, go into C/Program Files/Megasquirt and delete all the folders inside the parent Megasquirt folder except Megalogviewer and the Downloader for Microsquirt, just to be sure.
Ian.
Posted: Sun Mar 23, 2008 3:08 pm
by Dave Sloan
Yep, that will be good
