losing RPM signal around 800rpm
fastfreddie
Post by fastfreddie »
Here is a picture of starting!
fastfreddie
Posted by email.
krisr
Post by krisr »
Are you capturing on rising or falling edge?
I'm running an MSD pro-billet dist with the VR trigger circuit, rising edge is what i'm using. Your polarity is probably ok if you can get it started & running. I found that reversed polarity would not even trigger.
Sydney, Australia
fastfreddie
Thanks Kris!
It turns out i should have checked it out myself!
The VR trigger isnt' sensitive enough to run older "low" output VR sensors, a day of prodding and comparing led me to that conclusion.
Brgds
Freddie
