Page 2 of 4
Re: cheers
Posted: Sun Sep 03, 2006 6:02 am
by JakobM
bens_cab wrote:think i have it now ill compare my existing map to the one the configurator gives me
Great, Thanks
maps
Posted: Sun Sep 03, 2006 6:34 am
by bens_cab
here they are before and after
the before map was a starting map for me it wasnt tuned but here they are
Posted: Sun Sep 03, 2006 7:22 am
by JakobM
I cant open any .vex files. Can you make it as a picture or save it to any Microsoft office file. Thanks.
ok
Posted: Sun Sep 03, 2006 7:30 am
by bens_cab
ill try and save as a pic you can save then import into megatune
here you go
Posted: Sun Sep 03, 2006 7:34 am
by bens_cab
before and after
Posted: Sun Sep 03, 2006 8:27 am
by JakobM
Max advance seems to be strange here in the "after" map.
Could you poste your engine setup chosen in the configurator please. Thanks.
It would be very interesting to compare it with your "before" map. Do your present map ("before-map") run without any detonation?
run
Posted: Sun Sep 03, 2006 10:17 am
by bens_cab
the engine ran fine with both maps slight pinking on light loads but apart from that it seemed to drive ok
setup
Posted: Sun Sep 03, 2006 10:21 am
by bens_cab
valves 3
compression 8.5:1
bore 88mm
air temp 40 to 60 ave
squish 2
idle advance 10
max advance 33
max rpm 7600
Posted: Sun Sep 03, 2006 10:58 am
by JakobM
Very interesting. I need to know what max pressure you are running. Is it 250 kpa? or less? Again thanks for sharing the informaition with me
Your squish should also be choosed at "good" as you are running > 3 valves. Plus max retards is 24 and not 33. However something tells me the configurator for >3 valves might be too "Safe" > 100kpa.
There are big difference between the two maps specially in regards to the top-end retards. Your current map also takes peak pressure / max tourge into account (appr. between 3500-5500 rpm). The startup map dosnt. 100% prediction of max tourge area in a configurator is like the rest not possible though.
Posted: Sun Sep 03, 2006 11:30 pm
by Jon k
My generated map looks a little funky - its telling me to run 5 degrees of advance at 180 kpa
4v per cyl
10.0:1 cr
<88mm
95 oct
Average temp
Squish 4v
no WI
5 degrees is very retarded isnt it?
