Help needed with a 7MGE-T
So i didn't screw up on cutting the distributor....thats a relief! I guess i'll go back and make sure i didn't make any other dumb mistakes in the setup.
one question though. if the MS2 picks up on the wrong missing tooth won't it fire the coil on the exhaust stroke instead of the Compression?
Thanks,
Todd
If it fires on the exhaust stroke, it won't be because it picks up the "wrong" missing tooth. It will be because things were aligned so that when you reached the missing tooth, the next cylinder to fire (as determined by the dizzy) was on the exhaust stroke. If this is the case, it will also be true when you get to the next missing tooth, just on a different cylinder. You need to look at your crank damper and bring the engine to where no. 1 cylinder is at TDC of the compression stroke. Now look at the wheel inside the dizzy, in particular, the missing tooth that is closest to the position sensor, but has gone past it. This should be within a few teeth of the sensor. and the number of teeth past the sensor is the Delay_Teeth. So the processor senses the missing tooth, waits Delay_Teeth, and then you should be right near TDC of the compression stroke and it will fir based on the timing you put in relative to that. Now the teeth are pretty coarse - each is 30 deg at the crank, so you will have to eyeball or measure the exact degrees from the edge of the nearest tooth to thte sensor and put this into the trigger offset value.toddm wrote:
Todd
That said, you may have other problems. I say this because the processor has no way of knowing how everything is aligned and regardless of how it is, it should get an input on every tooth and should fire every 4 teeth regardless of where the piston is, and this fire should show up on the timing light. Of course if the piston is in the wrong place your engine or starter may not be too happy. When you ran the dizzy with a drill, did MT show a constant rpm - no quick drops to 0 on the guage. If so, but it does show rpm dropouts when you are in the car, then you may have a noisy tach input.
With the drill the rpm was nice and steady on the gage in Megatune and the signal looked nice and clean on the scope. while cranking the rpm jumps to 98 then Zero and back again. Also the Cranking /Not cranking indicator at the bottom of the screen is switching back and forth. I'll hook the scope up to it tomorrow and probably run a longer shielded twisted pair if it looks ugly. The factory Distributor wires were shielded but not long enough to reach the MS2
Looks like you found my problem! Thanks Mr. Grippo!
Todd
I also noticed the pulses look like avery high duty cycle and the spacing may be a bit uneven - can't really tell without blowing up the scale. But use a starting PulseTol of 70% to be sure that isn't the problem.
Thanks,
Todd
