No, The shape is one of the least important aspects. The pulse is reflected when it meets a change in gas composition, area, or temperature.FIntruder wrote:So is the shape of the reflective surface, the part of the plenum that the pulse reflects off of, important? Most plenums look to be curved in that section. Would a flat area reflect better? Then a square or rectangular plenum would work. .
This is much more complex than that. A short runner manifold at low rpm will definitely have many reflection cycles. They will reflect first emitting from the open intake valve and reflect back at the plenum towards the valve. Waves can undergo superposition when two waves meet. This totally alters the speed at which the wave travels. Plus the amplitude changes thus altering the tuning benefits. Very complicated subject.....FIntruder wrote:My project is a low revvin' motorcycle engine without much room for runner length. The lower the rpm, the longer the runner needs to be for peak. I guess it comes down to what it always does, you go with what fits. I'll have to do some math but is there only one length at which the pulses are timed right? With a shorter runner the pulse with move back and forth more quickly and thusly may have two peaks.
It seems to me a shorter runner will have many more waves hitting the valve at the right time. My runner through the TB and into the plenum may be about 8". Also two cylinders are sharing one TB and plenum so there are two sets of waves in there. That could be either really good or they may cancel each other out and my motor will not even start. I guess I'll be the first to know.
Matt
