Page 2 of 2
edis question 2
Posted: Fri Jul 14, 2006 7:23 am
by ranchero
So, correct me if i'm wrong.
The power goes to + on coil 1 and the minus of that coil to the + of coil 6 and the minus of coil 6 to a edis shannel.
If this is correct im saved and can use a verry neat setup of wasted spark on my engine.
See my page http://www.users.skynet.be/ranchoman
MSII V3 code 2.25
Re: edis question 2
Posted: Fri Jul 14, 2006 7:45 am
by Turbo4V
Correct!
Justin
ranchero wrote:So, correct me if i'm wrong.
MSII V3 code 2.25
ESDI MS1 Ford COP
Posted: Mon Jul 24, 2006 7:44 pm
by Curtis
I am setting up a porsche 928. Wiring the EDSI to COP, a question:
Connecting the EDSI Drive, does it matter which pin (left or right) facing the connector is connected to the ESDI drive output?
The other pin (ground) I assume as on the coil packs? However, there is a 25 mirco cap in series with ground for radio suppersion.
I assume the cylinder pairs receive the same drive and all cylinders should be ground with or without a capaitor?
Is this correct?
c
Posted: Tue Jul 25, 2006 1:03 am
by jsmcortina
The coils do not connect to ground.
One end goes to +12v, the other end goes to the EDIS module.
cop esdi
Posted: Tue Jul 25, 2006 8:49 am
by Curtis
does it matter which pin is connected to (switch+12) and which to ESDI unit?
Re: cop esdi
Posted: Tue Jul 25, 2006 8:57 am
by jsmcortina
Curtis wrote:does it matter which pin is connected to (switch+12) and which to ESDI unit?
Probably yes, this will determine the spark polarity. One polarity results in slightly less plug wear.
JAmes
Posted: Tue Jul 25, 2006 9:48 am
by PSIG
Coil polarty? This excerpt is interesting. I have used the pencil test before and it's more like a tiny plume than shower of sparks. :lol: I don't know how critical it really is but some claim a measured performance difference. I check mine, except for dual-terminal waste spark coils, where one plug fires forward and one reverse all the time. Tech manuals claim this is why they require more power to fire - as much as 5000 volts due to the backwards polarity on one plug. If wiring COPs in series, this might be important. Image
Champion Automotive Technical Service Manual wrote:... Spark plugs are sensitive to polarity and they will not function as
efficiently it the secondary coil voltage is of the wrong polarity.
The reason for this sensitivity is as follows. The centre electrode has
a higher temperature, normally, than the ground electrode so that more
electrons will be released from the hotter metal surface of the centre
electrode than from the ground electrode.
If the centre electrode polarity is more negative than the ground
electrode (which is connected to chassis) then the earth electrode will
attract electrons from the centre electrode; but if the coil secondary
voltage polarity is reversed, the voltage needed to cause electrons to
pass from the earth to the centre electrode (i.e. to make the gap
conductive) is increased.
Reversed coil polarity can be shown on an oscilloscope but a less
sophisticated test is to disconnect a plug lead with the engine running
and form an arc between the plug terminal and the end of the cable.
If the point of a soft lead pencil is placed in the path of the arc then
a shower at sparks will be created, either on the plug side (if polarity
is correct) or on the cable side (if the polarity is incorrect). The
condition of the plug will also indicate reversed coil polarity if this
situation has prevailed for some time. The use of the oscilloscope is a
more sophisticated means of determining the states of the engine,
ignition and fuel systems than the condition of the spark plug.
