Posted: Sat Jul 08, 2006 9:41 am
Don't forget folks that .001 resolution is not mandatory for tuning your idle - just tweak your fuel pressure up or down to the next .1 setting based on the over/undersize of your injectors so it's perfect. Idle is the first thing you tune and the base pressure can be tweaked at this time for a solid idle mix and the remainder of the VE table tuned from there. Hi-Res is nice but not a requirement for fine-tuning with huge injectors.
FWIW,
David
FWIW,
David
