This is more cureosity, not exactly advice to millhouse.
I am wondering if you could set the cranking RPM very high... reasonably higher than normal idle. And make the engine run on the crank PW. What this would do is eliminate all fuel paramaters except the cranking pulse. Which would be acting like a idle PW.
Then you could crank a few turns, increas crank PW, crank a few more. etc.
The problem I see with this is, for my engine to start best I need a crank pulse about 4 ms but idle is about 1.5 ms. So enough fuel to get it to fire might then flood the engine. This is because the cranking map is much higher than idle map I supposed.
Later today when I have the computer in the car I will see If I can make this work...
Also, I don't know the code you are using but I see
Code: Select all
<constant name="CrankAng" units="Deg">10</constant>
<constant name="FixAng" units="Deg">-10</constant>
<constant name="IdleAdv" units="Deg">-10</constant>
<constant name="IdleAdvCLT" units="F">-40</constant>
Are the negative angles advace or retard? Or are you using a different ignition mode? I only know about EDIS.
And, if you can, make sure you are getting good voltage DURING CRANKING so you know the fuel pump, injectors and ignition have enough to work. My speculation here is that maybe unloaded you have enough power for a good prime pulse but the voltage is dropping too much from the starter load.
Sorry if I added more confusion than help
