IDLE PWM valve configuring
johnc32779
Post by johnc32779 »
Nuts, in my first post above:
after warm up are you using the 3-wire idle valve to control idle speed? If so, I am puzzled as I can find that ability in MS-II
should read:
after warm up are you using the 3-wire idle valve to control idle speed? If so, I am puzzled as I can not find that ability in MS-II
MOPS, thank you for your prompt reply. I think we are now both on the same page, and your input is helpful. Today, I got my engine idling for the first time and very quickly came to the realization that MS-II currently has no explicit ability to set idle speed. For some reason I had it in my mind that MS-II had closed loop idle control like the Motronic system I am replacing. Then I starting reading the tuning instruction for setting idle by adjusting the VE table for lowest MAP while keeping RPM constant by adjusting the idle screw as required. At this point I was saying oh sh%$ to myself -- what have I gotten myself into. Anyway, your last post has given me incouragement that I haven't totally lost my mind, and there is light at the end of the tunnel.
mops
Post by mops »
ok, to get idle stable you need the following:
1. stable IAT reading (ms will compensate, co if you tune it at 20deg C, it will idle higher at 8 deg C )
2. stable timing.... my engine generally incerases idle speed by 100 rpm per 1 degree of timing around idle map/rpm point. It is crucial to have stable timing there otherwise idle will be rolling
3. control over pwm idle valcve
4. tune idle only when fully warmed up - that idleudes warmed up oil pressure/temp not just coolant at normal operating temp
5. tune for lowest kpa around stock idle rpm. i'd stick on trying to 14.7 air/fuel for now. you can lean it later.
5. once you have done all of the abouve then tune your ve... shouldnt be very difficult.
cscm094
Post by cscm094 »
Anyone have a working link to that picture?
3-wirev30.jpg -- seems to be dead.
cscm094
Post by cscm094 »
Anyone have a working link to that picture? 3-wirev30.jpg -- seems to be dead.
Posted by email.
cscm094
Post by cscm094 »
Posted by email.
cscm094,
The link should be working now (along with the rest from the forums). Thanks to MoveX for the 'heads up'!
cscm094, The link should be working now (along with the rest from the forums). Thanks to MoveX for the 'heads up'! Lance.
Forum Rules --- No responses to your posts? See this. MegaFAQ --- MegaManual
Posted by email.
