MS2 Wheel Decoder and Trigger Offset Questions
I'm just trying to remember back when I fitted a direct ignition HPV-1 to a friends 383 Chev, from memory it HAD to be on #1 TDC firing with the sensor aimed at the trailing edge of the 11th tooth to put it in the ballpark to fire with 0° of advance, each tooth after that represented a 6° advance before you started to play with the advance on the module itself.
I guess my question is, does it also matter which edge of the tooth you set your sensor on also like the HPV-1?, e.g. I have a 36-1 tooth wheel at the moment. If I rotate the motor to #1 firing TDC, setup the sensor to be on the trailing edge of the 9th tooth my settings would be
Wheel: 36
Missing Teeth: 1
Skip Teeth: 9
Delay Teeth: 9
As far as your 36-1 wheel, the skip teeth = 36 / (no cyl/2) = 9 for an 8-cyl car. The next consideration is that the trigger offset is measured with respect to the first tach input following all the missing teeth + delay_teeth. I would set that tooth up to be 8 or 10 deg BTDC. The use of delay_teeth is just a convenience for people who can't easily rotate their wheel or crank sensor to any position. You can make it 0 if you want.. The only restriction is that you can't have a tach input come in on a mssing tooth. So pick a delay tooth that is convenient. Then start counting 9 teeth from that tooth until you come back to where you started. This gives you all the tach in teeth - if any of them falls on a missing tooth, then you have to change the delay_tooth value.
jsmcortina
- MegaSquirt Guru
You need the MS1/Extra code for that processor, take a look at:Bengt wrote:Hi Lance or Grippo
More question to Renault 5 Gt Turbo cars(controlling spark ).I am installing V3.0 68HC908GP32 processor ,And i see only router will handle that ?.Can the code from router board moves to 68Hc908Gp ? .
http://megasquirt.sourceforge.net/extra
http://megasquirt.sourceforge.net/extra ... wheel.html
James
jsmcortina
- MegaSquirt Guru
If you have a specific problem please ask about it in the MS1/Extra forum.Bengt wrote:I have 029q2.but long tooth make some hell.
James
