Page 2 of 2
Posted: Wed Jan 25, 2006 11:16 pm
by lukep
Thanks Guys for all the input. As M0ntecarloss put it anything Vortec ends up more expensive. Kinda wishing I bought some Edelbrock Aluminium heads instead. Oh Well. ChevelleFan I am very keen to hear about your results. Keep us posted
Luke
Posted: Sat Feb 18, 2006 8:01 pm
by blackmonte355
lukep,
Build the single plane with port injection, you WILL NOT be short on low and midrange torque.
Here is my set-up:
1) 455 Buick
2) T/A Performance sp-1 highrise alum. intake, homemade conversion to MPFI
3) home made "airbox" 6"x5"
4) BBK TPI 58mm throttle body
5) Megasquirt MS-1 v2.2 board
Before I built the FI for the engine, which is in an 86 Regal by the way,
I was using an Edlebrock Q-jet series carb. Now with the FI, it feels like I bolted on a 6-71 blower. Kind of an extreme comparison, but it's the only way I can put into words how low and midrange torque have increased.
As for top end is concerned, It has also increased, but I have not been able to get to the track to test it. I have 1/4 times of the car with the carb, and I ran a 12.83 @107mpg with 2.75 gears in the 9" rear.
My B&M converter with the carb would stall at about 2300, now with the FI it goes to 3000 and then some. I say then some because just today I was stalling hard for the first time to see how high it would go, well I got it to 3000rpm and the rear u-joint broke, mmm-kkkkk. So now it's time to upgrade the driveshaft, u-joints, and yokes.
So screw the TPI manifold, build a MPFI with a single plane intake.
Dean
