AFR Table where to start?
boost junkie
Post by boost junkie »
Professor, I'd go richer in boost. @ 170kpa 13:1 air/fuel is dangerous. Above 100kpa dip it into the 12:1 range real quick...
-shawn
msns-e controled turbo neon
sample msq's!
efahl
Post by efahl »
boost junkie wrote:Professor, I'd go richer in boost. @ 170kpa 13:1 air/fuel is dangerous.
Oh yeah, I'd say more like 10.5-11:1 for the high boost sections of the map until you have some experience with the motor and have the ignition dialed in fairly well. This will kill power, but shouldn't kill your motor.
Eric
Mad Professor
Post by Mad Professor »
Something more like this?
efahl
Post by efahl »
If you have a catalytic converter, everything below about 90 kPa should be 14.7. If not, then lean it out a whole bunch and save some fuel. Go as lean as you can before you get lean misfires, usually 16.5-17:1 with most ignition systems.
Eric
ChaosAD
Post by ChaosAD »
Should the AFR below 90kPa change with revs too? or just be the same throughout the rev range?
keithmac
Post by keithmac »
Is this for closed loop mixture control? if your O2 sensor goes bad on boost you may destroy your engine.. I manually mapped the boost section on my MS1 but MS2 may work differently?
Squirted VW GTI 16vG60 mk2
