Help me! megasquirt Vacum
When I try to start my car, it doesn't start until I disconnect the vacuum to the megasquirt. If I start my car without the vacuum connected to the megasquiert, it starts without problem and turns normally. When the motor is running, if I try to connect the vacuum, the motor stops. I see on the computer that if I connect the vacuum to the megasquiert, the mSec injection stops. On iddle it turns at 1100 rpm without the vacuum. On the computer it appears 96 Kpa and 8.4 mSec.
I need help to find a solution.
I had try to modify my VE TABLE, without result. I also had my IAC disconnect without result.
I also had my motor turned to 2200 rpm without the vacuum connect to the megasquirt, when I connect the vacuum, keeping 2200 Rpm, my motor still turns, but very not well.
What can I do?
Thanks for your help.
J-P
whittlebeast
