Ok, so I used the generated VE table from MT, got the idle nice and smooth and low kpa, and then did a little autotuning and manual smoothing of the VE map, I took it for a drive, and the thing seems to be running extremely well. (I've barely done anything!) It holds 12.5-13 AFR under full throttle accel, and under cruise it runs at 16-17AFR. Idles smoothly at about 28 kPa,and all seems well. Even gave me the confidence for several WOT 6000RPM runs. I guess I just want some of you experts to help me find out dangerous points in the map.
I have not set up AE, and TPS is not being used. Also, CLT is still reading about 20F too low.
What do you guys think of these logs?
