INJECTORS---how big is to big
cododgeneon
Post by cododgeneon »
i was planning on buying a set of #96 injectors but i heard they might be to big to idle at 850rpms.
what do you think?
my plans are big, somewhere around 450-500whp...
i have supporting mods and wanna get the injectors out of the way.
thanks
tyson
IM SLOW
efahl
Site Admin
Post by efahl »
Tyson,
How big is the cylinder that each injector will supply? If it's 500 cc or bigger, I would think you could make it work with MS-I, and make it work quite well with MS-II.
Eric
danc8000
Post by danc8000 »
Has anybody got any sort of calculator that can kick out pulsewidths and duty cycles for different injector flowrates in different sized engines? Anything?
whittlebeast
Post by whittlebeast »
see http://www.ncs-stl.com/fuel/ReqInjectors02.xls
It does not address idle and low rpm Pulse Width. It concentrates on the high HP end of injector sizing.
AW
danc8000
Post by danc8000 »
Thanks for the link, I do alreasy have that spreadsheet and it ties up with some I have put together over the past couple of years.
I am more after something that will calculate pulsewidths, I know this is not easy and there are a lot of variables to consider. I guess I'm looking for an online Megasquirt, where the outputs can be read on the screen!
cododgeneon
efahl wrote:Tyson,
Eric
the motor is 2400cc---2.4L.
IM SLOW
