Controlling edis4 with micro v3
1986mitz
Post by 1986mitz »
Hey how's it going .. I'm about to install EDIS 4 on my starion 2.6 motor . Was wondering if any of you had good experience controlling timing advance. Just want to make sure it's straight forward .. Don't want install and be stuck with 10 degrees in limp mode all the time.. Thanks any input would be great ...
1986mitz
Re: Controlling edis4 with micro v3
Post by 1986mitz »
No takers lol.. I'm sure someone has done this. Thanks for any help. I got my brackets fabed up its going in soon. Wish me luck .
It is pretty straightforward; did you have any questions about how to set it up?
1986mitz
Post by 1986mitz »
Hey Matt.. The setup looks pretty straight forward. My only question so far is on diagram it shows pin seven from EDIS module , has a loop around vr wires labeled shield and the same around the saw and pip wires. I'm assuming u shield these wires , but is pin seven a ground that needs to be tapped together in with shield? Thanks
That symbol is a shield.
