I custom made my own 10 Kohm NTC temperature sensors because of where they had to go in my application. I wanted a very small sensor tip for my air intake sensor so going with GM style sensors was not going to work. Here is my question:
If the actual thermister has only two leads because it is essentially a resistor, what is the third wire for? If the third wire is supposed to be connected to VRef, how does it get wired to the sensor?
Is this close? If so, what size resistor goes to the 5 volt line?
