Tunerstudio Dashboard
Saverok
Post by Saverok »
Ok Noob question I can't find the answer any where :RTFM:
How do you change the Dashboard look after you have already started a project?
LT401Vette
Re: Tunerstudio Dashboard
Post by LT401Vette »
Either right click on it or from the File --Gauge Cluster Menu, select:Load / Save --> Load Dashboard
You can also add additional dashboards by clicking on the right most tab at the bottom. Then a new Tab will be added and the Open Dash Dialog will come up.
Also you can right click and select Designer mode, then add, move, remove, change gauges.
Phil Tobin
EFI Analytics
http://www.efiAnalytics.com/
