How do you feel about this installation?
anesthes
Post by anesthes »
400" small block chevy
Small cap "HEI" distributor/module with remote coil
8, high-z injectors, wired in two banks parallel (42lbs ford green tops)
2-bar GM map sensor
Innovate WB02 (LC1)
supercharger
manual transmission
I don't need fan control, trans control. All I need is reasonable tuning resolution for my target AFR, fueling under boost, control of my spark table (cranking, idle, and advance vs RPM/MAP)
From what I've read, the Micro will drive the injectors, and provide the functionality I want. How do you folks feel?
I'm also considering the hybrid MAP/MAF install.
-- Joe
