uS Timing accuracy problems
Re: uS Timing accuracy problems
I wanted to make sure I was understanding all of this correctly, so I marked up the picture I took of the scope at 135 offset and 5 deg spark timing, 1450 RPM. Could you verify that I have this right? I still don't understand how the timing signal can occur before tooth 7 trigger. What is still more confusing to me is why I see a huge jump in timing for only a 1 degree change in requested timing. Last night I collected more data at different rpms and noticed the large jump in timing occurs at different requested timings. I ran this test in two ways and got the same results. The first time I set timing to a specific value and swept rpm until I saw the jump in the timing signal on the scope.
Sweeping speed:
RPM Timing where jump occurs
1250 5
1470 4
1780 3
2100 2
2400 1
2950 -1
The second way I ran the test was to fix the speed and sweep timing at each speed until I saw the timing signal jump.
Sweeping timing:
1200 5.05
1500 3.95
2000 2.15
2500 0.75
2975 -1.05
I realize that these are not realistic timing values, but if I choose a different offset for my trigger I can easily get the jumps to occur in the range of useful timing values. This seems like maybe it's another clue as to why my setup is doing this. If it's helpful, I could run the same sweeps with different trigger offsets and add it to the plots below. Is there anything I can log that would help solve this? Is it possible to add different internal code variables to the log files by changing the *.ini file?
- Attachments
- bgeisick_myphoto_4.3 deg.JPG (116.38 KiB) Viewed 1169 times
- bgeisick_myphoto_7.3 deg.JPG (107.43 KiB) Viewed 1169 times
- bgeisick_myphoto_30.9 deg.JPG (98.05 KiB) Viewed 1169 times
