Spark_Fuel_Offset vs Auto-trigger?
Dan_Austin
dedictaed to sequencer differences. The Spk_Fuel_Offset looked
interesting, and made me wonder on my even fire straight six exactly
where injection was occuring.
I am using TS 2.05 and did not see an option for Spk_Fuel_Offset, but upon
browsing the ini, I see that is set to not be available if Auto trigger is enabled.
I currently have the 'Injection Timing Angle(deg)' set to 48. If I am understanding
what I have read, that would place the injection event, assuming timing of 20 degrees,
at 72 degrees before TDCC2, which is also assuming that Spark_Fuel_Offset is defaulting
to 0.
After re-reading that section and the Megamanual section on Injector Timing Delay, I
realize that my setting of 48 is likely a poor choice, largely influenced by the example
in the Megamanual. Before I start altering it to test the results, I hoped to see if
my understanding was in the ballpark.
Re: Spark_Fuel_Offset vs Auto-trigger?
Dan_Austin
and failed to note that in the manual this setting was in percentage units, but the TunerStudio releases
I have used is in degrees.
540 degrees mad more sense, but after misreading that section I was thinking I needed to use the
Spark_Fuel_Offset and small delay degree to hit the injection mark I was aiming for. I'll correct
my mistake and adjust as needed.
On a side note, is there a place that lists the version change log? I have 3.770 running and see
that a 3.780 firmware is available, but no indication of what changed or if I might want or need
it.
The only change for 3.78 was to fix broken logic for non-wheel mode. This won't affect most people using the Sequencer, since they have wheels and are in Dual Spark mode.
