Ok another newbe question here. I am stuck again.
I have an innovate WB O2 sensor and Gauge that has been working fine for months. But I cant get MS to play with it. I thought this would be the simplest hook of all, one wire, and the O2 sensor is one of the ones that is listed in TS, but so far no luck. I expect it is another set up issue but I have about run out of things to try. The sensor is good, I get good readings on the wire but the gauge seems t be frozen at around 19 AFR. If I calibrate and select different sensors or manually set up a range, it changes to a new set point on the gauge but never moves after that.
Here is my set up. MicroSqurit V3.0, running V3.77 SW. TunerStudio latest version and registered.
The target is a 2008 Suzuki DR650 single cylinder motorcycle. I am going for fuel only, at least for now.
I have RPM, CLT, IAT, TPS, and MAP hooked up and all read fine. I have WB LM-1 selected for EGO setup and for the calibration table.
Any ideas?
Thanks in advance,
John
