Can not get MS to connect to laptop
isaacson06
Re: Can not get MS to connect to laptop
Telling us you 'tried every last thing' is essentially telling us nothing at all. If you don't have a serial connection, you won't be able to load code. Trying what 'some people said' isn't usually too helpful either. You need to read and understand the manual.
If this was mine, I would follow the steps here: http://www.useasydocs.com/details/connect.htm and then let us know explicitly what you find at each and every step.
isaacson06
- Master Squirter
FWIW, I had comms issues with MicroSquirts over the last few years of dabbling, and normally a reinstall of the firmware sorted everything. I am using a Mac, so that brings its own problems, as I had to do Windows via Bootcamp or later using Parallels. Unless you have a very early version MicroSquirt, red PCB IIRC, you are probably at a fixable point, so don't fret help will probably appear.
Unfortunately yours is a very generic post and will need to throw more questions into the ring. Do you see any comms port activity? Have you tried serial comms with anything else. What error messages are you getting? and without being rude, you need to feed the guys with details, because generalisations aren't enough, but I do understand your frustration.
isaacson06
isaacson06
isaacson06
Firmware mismatch
this is tunerstudio
this one is megatune
two stroker
found it its under www.megamanual.com/files/ini/ at the bottom.
- Master Squirter
+1 You click on the Update ECU Definition, and if TunerStudio is new enough, I'm using the beta version, it should find the ini like mine did.two stroker wrote:...you need the new 3.770 ini file for tuner studio...
PS I have had comms issues in the past and it was wear & tear with the MicroSquirt supplied jack plug to serial lead, which is why I bought a RS232 Serial LED diagnostic tester off fleaBay, and now I have a visual indicator too.
isaacson06
