Hall effect sensor connection on a microquirt
currently trying to use an hall effect sensor from bosch part number 0 261 210 148 on my distributor for rpm input. This part has tree connectors: a ground, a shield and a signal output. According to the literature for the hall effect, we need a 5 volt reference, ground and an output. Not sure how's this work with this sensor. In addition, on the microsquirt wiring diagram, only 2 wires connection are used: output to pin 30 and a ground to pin 31. Is this pin 30 assumes a signal from a 5 volts reference from the hall effect sensor? Is the ground at pin 31 the same ground of the sensor ground?
thanks for clarification.
Alain
Re: Hall effect sensor connection on a microquirt
- Apply constant voltage to pin 30 and a ground triggered input on pin 31
- Apply a constant ground to pin 31 and a voltage based trigger to pin 30
The sensor can use VREF (pin 28) for voltage and the main sensor ground for its ground.
I am not sure that this sensor from Bosch is an hall effect and should be connected to pin 30 and 31. I believe that it is a VR type sensor and pin 32 and 33. Have a look at the datasheet and drawing from this site. Look at the sensor 0 261 210 136, it is the same as the one that I intent to use http://www.bosch-motorsport.com/content ... l/2874.htm
Any comments are welcome.
Alain
The optoisolated circuit needs at least 10 mA to trigger reliably. I'd use a 470 ohm pull-up instead of 1K.
thanks
