My Set Up
2002 Yamaha R1
microsquirt v2 board
Bosch 211 igniter for COP
16-1 crank wheel VR input
1 tooth cam hall sensor input
Optima red top batt
11ft of 6 ga starter wire
A picture of my 16-1 crank wheel:
It is oriented so that TDC of Cyl 1 occurs first tooth after missing tooth. The missing tooth synchronizes nicely with slowing rpm from the compression of the motor to make a visual distinction. See oscope trace below.
+/- 2.1V amplitude.
Compression tooth to tooth gap 22.5ms.
Regular tooth to tooth gap 7.75ms.
Missing tooth gap 45.5ms.
However I am getting significant noise from the starter (If the engine eventually catches and starts it runs fine.)
This leads to false triggers and poor crank sync.
I tried adding a 10k Ohm pot on the VR1+ but it didn't help the noise.
VR2+ is attached to the hall effect on the cam sensor.
VR1- and VR2- are on same pin 33.
6ga batt ground direct to engine block 10ga ground from engine block to sensor ground bus.
Starter rpm in 250-350rpm plenty CCA from red top battery.
Measured VR sensor gap (stock setting) to be .15mm
I'm having a hell of time getting it to start, please any suggestions are appreciated. I was thinking of ordering a Hamlin hall effect if this starter noise is incurable.
