Durability ?
Durability ?
Re: Durability ?
- Master Squirter
Re: Durability ?
Re: Durability ?
Bruce Bowling
- Site Admin
Re: Durability ?
Originally the plan was to offer the enclosure sealed, but the options available were not that great. Also, the case needs a positive pressure of 1 psi or so, preferably filled with an inert gas - but then if its opened then this is lost.dontz125 wrote:Ok... I'm not used to speaking out my backside, but there you go. I truly thought the silly thing was sealed.
You can always apply sealer on the end plates as suggested.
Also, the PCB is conformal coated, enough to prevent issues with condensation but not to immerse underwater.
Re: Durability ?
http://www.microsquirt.info/The MicroSquirt® board uses the 35-pin AMPSEAL connector and a sealed case to make a fully sealed unit.
That would explain why I thought it was sealed... Both your own info page, and every vendor I've seen, uses that or similar text. I'm not trying to be a dick, but in these lawsuit-happy times, that could let some ambulance chaser set you up for a false advertising suit...
Bruce Bowling
- Site Admin
Re: Durability ?
You are right - we have corrected this statement in the documentation. As explained before the board is sealed with conformal, but the case per-se is not sealed. So the board/ampseal is sealed for incidential mosture, but the case is not.dontz125 wrote: That would explain why I thought it was sealed... Both your own info page, and every vendor I've seen, uses that or similar text. I'm not trying to be a dick, but in these lawsuit-happy times, that could let some ambulance chaser set you up for a false advertising suit...![]()
One thing to note is that Microsquirt is still DIY in nature, and it turns out there are reasons where one would have to go inside the box (like for example to set ignition jumper positions). If there was a factory seal, the first time it was opened the seal would no longer be valid. The conformal coating method is a good alternative to protect against condensation, etc.
If someone absolutely needs the case sealed we can post instructions on how to do it (its not very difficult) - but be sure its the last time you want to go inside the case, otherwise the seal will be gone and you will have to re-seal again.
