Need help with altitude compensation.
tech3sandcars
Re: Need help with altitude compensation.
If I stay with the current setup I will dial the air temp thing in on the dyno, maybe use a blow dryer to heat up the air temp, where I dyno at is much cooler and air is more dense so I don't think I have to do any cooling, I think I can extrapulate the line when I dial in the high temp end.
Thoughts about the MAF?
I have tried to clarify and fix the ini file, and a new one is attached. In looking at this I found that both alfa-N modes are blend modes, but the last mode only uses tps in the VE table lookup, it doesn't also multiply VE by tps the way SD multiplies VE by map, and since barocorr is tied to this tps or map multiplier, it also isn't used in the last alfaN mode. (This is clarified in the new SD/AlphaN selection menu.) So just use the middle alfaN option if you want to take the most account of barocorr.
- Attachments
- megasquirt-II_v3430.ini
- (130.54 KiB) Downloaded 176 times
tech3sandcars
So I have a more general question about using blending ( I think I will wait to try MAF in the off season), this motor is a VTwin engine with pretty radical cams. Like I said earlier it idles between 75 and 85 KPA, thats mainly why AlphaN is used, but is there any point in a motor like this where blending to MAP would do me any good? This motor is attached to a CVT belt system so 90% of the time the motor runs at a specific RPM, in my case about 8500rpm. So from the minute you punch it it revs to 8500 and just holds there while the clutching works to accelerate the vehicle. Any thoughts there would be helpful.
thanks
