map sensor on a 2 stroke
redbulltbo
Post by redbulltbo »
Can anyone tell me if I can use a map sensor on a 2 stroke and if so how would I. I searched the forums and could not find any topics on this.
Thanks in advance, Tony
mxrob
Re: map sensor on a 2 stroke
Post by mxrob »
redbulltbo wrote:Can anyone tell me if I can use a map sensor on a 2 stroke and if so how would I. I searched the forums and could not find any topics on this.
I don't see why not. There is still manifold vacuum on a two stroke engine between the reed valve and carb slide/TB butterfly. Like any single cylinder engine you'd likely have to run Alpha-n blending because of the on/off pulsation of the signal at lower RPM... and possible loss of MAP changes at higher throttle openings (reaching max KPA before reaching full throttle).
DR650 Dual Sport thumper µs FI success!
