Map sensor changes readings for no apparent reason
Thanks in advanced
- Attachments
- 2010-05-17_18.26.35.msq
- (25.9 KiB) Downloaded 87 times
- 2010-05-17.msl
- (1.01 MiB) Downloaded 85 times
Re: Map sensor changes readings for no apparent reason
I will give this a try and see what happens.
It worked for about 6 hrs of run time and then it started acting up again. I hooked the laptop to it and the map readings were off. I changed a couple of cells on the VE table and hit burn and it went back to its normal readings. Changed another cell and hit burn again and the map readings jump high again. Could there be something wrong with my embedded code file? When I reflashed the code into the microsquirt and then loaded the tune my hand it ran great, I could change cells in the VE table and hit burn and everything would stay like it should. The machine ran great and gave no problems but after we had about 6 hrs of run time it all started again.
Your msq appears to be ok, but keep track of it.
grippo wrote:In looking at your datalog around 1280 to 1320, you will see that the MAP going nuts is related to your trigger+/- column. The errors count down (missing wheel pulses) and then they stabilize and map also stabilizes. This may mean there is a noise in the VR circuit that comes and goes. Also the trigger+/- is extremely high - this number should stay very small - mostly there is just some small changes at startup and when you cut off the engine.
Grippo,
When you say the trigger +/- column are you referring to the task masking signal? I have not adjusted anything for the trigger +/- columns I left that at the default settings. I'm not sure where the noise is coming from. Can I put a filter on the VR line somewhere?
It doesn't appear that the long/ short tooth counts are causing any loss of synch because the rpm never goes to zero and the code is capable of correcting for one missing/extra tooth as long as there are not 2 or more consecutive ones. So I'm not sure this is coming from the VR sensor. It appears to be more related to the fact that you have the laptop plugged in, or if not that, there may be some flaky connection, maybe in the map sensor, that comes and goes. When map jumps around like that, the fueling will jump around and this will definitely make the engine run like crap. If you drive around without the laptop connected, does any problem occur ?
Yes, I reloaded the embedded code and then reinstalled the .msq entering everything back in by hand (as Matt suggested) instead of loading the .msq file. The machine ran great for about 6hrs and then it started acting up again. I then connected the laptop to it to see what it was doing and saw that the map was reading high again. I changed a cell in the VE table and hit "burn" and the map reading dropped back down change another and it will jump up again (it doesn't do it everytime but very close). I have also noticed that If I change anything in any of the settings it will also cause the map reading to jump. I soldered all of the connections and I have tried wiggling the wires at the map sensor but I can't seem to get it to change by doing that, I tried another new map sensor and had the same results.grippo wrote:If you drive around without the laptop connected, does any problem occur ?
I just looked back at datalog and notice that at about 1295 the tachcount drops to zero and then the map sensor starts reading high. What does it mean when the tach count goes to zero and what can I do about it?
Also I looked at a datalog of another machine that I did that is identical to this one and noticed that the trigger +/- column on it did not move much at all. I noticed that it might move up or down 1 throughout the entire dataloog where this machine the trigger column runs up and down constantly. BTW this other machine runs great and has had no issues. Can the air gap between the vr sensor and the trigger wheel cause this?
Yes the air gap can cause a problem, but it usually shows up at low rpm where the signal is naturally weak. The Trigger+/- definitely should not be a very high number,
If you can get a second unit from another car and load it with the same msq I would try that to rule out a hardware problem. Meanwhile I will test the msq on the bench and see if there are any problems, but this really looks like a hardware issue, either with the car/ VR sensor or the microsquirt.
I just got through converting the 3rd machine. All of three of these are identical units and I have used identical components, wiring layout, etc. The third unit that i just finished, I loaded the msq into and test ran and the unit runs great. The trigger +/- column doesn't move until the tach count gets to 65535 which is when the tach count resets, which is normal. The first one and the third one run great, but this second one is giving me a headache. I would say that it was something that I did wrong but since the first one and third one run great and I did everything the same then I'm hoping its not me. Maybe there is something wrong with the vr sensor? I can take it back and get a another one and then recheck my connections, but do you think it is safe to say that it is in the VR circuit somewhere?
