I do have a question that bothered me the last few days.
With a wasted spark setup, what boundary is a "trigger - dwell - spark"-cyle not allowed to cross? What numbers add up to an ignition cycle's time?
I did observe rev limiting behaviour (like retarded ignition) above about 10000 RPM now that the new enginie is broken in. Tried to move the tooth gap around by adjusting the trigger wheel which helped a bit but not much.
What helped, eventually, was to reduce dwell. Dwell for my coil is originally specified to 2.5ms, by reducing it to 1.7ms the engine still runs good but now easily revs 12500 RPM and more (didn't dare to try where the limit moved to now with an enginge still new).
I have a wasted spark setup with one single coil alternatively charged by IGN1 and IGN2. The tooth gap/trigger point (18-1 wheel) is located roughly at -180°BTDC/+180°ATDC. Max advance is about 30°.
With the observed behaviour, I'd assume that IGN1 and IGN2 cycles overlap above a certain RPM leading to interleaving charging/discharging cycles for my coil.
I did some rough calculations adding up times for advance, spark and dwell, but didn't really find an explanation.
- Bildschirmfoto.png (22.56 KiB) Viewed 1661 times
Although 2.5ms dwell equals to 180°at 12000RPM, there should still be plenty of time without disturbing the other IGN output.
What am I missing?
