Code to fix offset/delay teeth
I'm going to be gearing up soon to re-fit the sequencer to my Pontiac engine in the coming weeks and I was reading that Al had stumbled upon the bug where the offset and delay teeth for those of us running chopper wheels had to be messed with quite a fair bit. I was curious if that code was ready to be released to beta or should I just try and find the "sweet spot" like Scott/TheMonkey did?
Hope all's well!
Kris
Re: Code to fix offset/delay teeth
Did Bruce ever get his CBR engine running on it?
I will send you my address. Yes I think it will be the last rev requiring a change in the router cpu. Anyone can burn the code with a bdm cable and the free version of Codewarrior, but the cable is about $100. And no Bruce still hasn't tried it on the CBR engine. But we are giving the board spin a final review this week and should have it ready to send out next week.
I am having a similar issue with tach resets at certain RPM's as Scott and theMonkey have experienced. These tach resets move per my offset/delay teeth settings and with delay teeth @ 0 I have no tach reset (BUT get shrinking dwell at high RPM). So it sounds to me I may have the same issue. Unlike these guys, I don't have the sequencer (router board) so I should be able to upload new code... is there any way I could get a beta level code to try uploading to my uS to see if it fixes the resets? Or is there new sequencer code out there beyond 3.23 that addresses this?
Thanks!
Tonight I can try to get a datalog of the tach reset tonight then change the code to 0 offset and get another data log in the same rpm range if this is helpful.
Regards,
Rob
- Attachments
- 2009-11-04_23.28.42.msq
- (23.98 KiB) Downloaded 269 times
If the problem is only at high rpm (> 4 or 5000 rpm), then you may be reaching the limits of the processor or your VR signal may be changing at these rpms. When you get into the higher frequencies you start getting capacitance effects on the signal that can cause noise and phase shifting.
If it works fine at low rpms then the base code and configuration should be sound but the OUTPUTS can get screwed up at high rpm if you have trigger offset, delay teeth set non-optimally. But this should NOT cause dropped synchs (rpm = 0, trigger+/- counting up/down). It should just cause missed outputs because the dwell + spark advance time isn't optimally placed inside each double tach period. For example if your delay/ trigger offset is such that you need to spark 1 ms after you start tach1 period, then you aren't going to have time to get enough dwell; at the other end you may spark prematurely when tach3 occurs.
All I can do right now is wait for your data logs then look at that specific case, and try them and see if I get loss of synch. If the rpm is above 4000 rpm I will use a 60 tooth wheel, since there is no difference in logic between 60 and 130 teeth and I can scale the delay teeth to match your delay teeth.
I have never experienced tach resets or tach loss above 4000 and have been as far as 6500 before.
Al, thanks for looking into this. I frequently drive the car (have 3000 miles on since changing to spark), this is just an annoyance to me, not a show stopper but it'd be great to solve. More-so out of my curiosity of the source of the problem.
At this point I'll change the code back to 0 delayed teeth and -305 degrees offset and drive it for a while and see if I notice any tachloss.
Thanks again!
- Attachments
- 2009-11-14_13.20.05.msl
- (21.2 KiB) Downloaded 271 times
