http://www.microsquirtmodule.com
What we have done is taken the complete Microsquirt board, removed the AMPSEAL connector, and replaced this with 2x25 header (0.1 inch standard). Additionally, extra processor signals normally not brought out on the regular microsquirt, are available on another header (2x5) - usable with the MS2extra code. Also, the IGBTs are removed and only logic-level ignition outputs are available for ignition - the injector drivers are still on-board.
The goal of this board is for total DIY - its for people who want to design their own mainboard using the connectors+peripherals of their own choice. None of the headers are soldered in so that you can mount the header either on the top or the bottom of the board. In other words this board is not standalone, its a building block for your dream EMS solution.
The price of the board will be US$250.00 in single quantity and will be available the beginning of August 2009. For higher quantities and production situations talk with DIYAUTOTUNE for quantity pricing. Board comes programmed with bootloader and B&G MS2 code V2.890.
We hope this fills the need for those wanting your own custom solution. It also opens the door for many custom solutions, like USB, Bluetooth, redundant EFI, etc. Also with the CAN connectivity further expansion is easily achievable.
Have fun
