Buell
Buell
I have installed an microsquirt on a friends bike wich have an 2 cylinder 1200cc oddfire harley engine with turbo.
It is set up as dualspark.
The software is BG2.890.
The engine runs, but the mixture is all over the place.
The problem seems to be the the mapsensor or the timing when the microsquirt take a sample from the map,
coz the map jumps upp and down in big steps.
The variations in the inlet is very big on this engine.
Is there any good solutions to make the mapreading more stable?.
Regards
Øyvind
Re: Buell
Re: Buell
I `ve got an idea that am going to try out.
Am a little into atmel microprosesors, so i was thinking to make an co-prosessor that will sample
the map-pressure with one ADC channel, and on the lowlevel of the "inlet sinus" it will update the timer wich is set as pwm-output.
This way the microsquirt will always see the corect inlet value when it decide to sample the map.
i have the little program ready, so i will tell how this experiment went after i have tryed it out.
Øyvind
gboezio
Re: Buell
gboezio
Re: Buell
I'm running a 12-1 tooth wheel with a VR sensor at the crankshaft
a single tooth cam Hall type sensor fed by 5V vref
I saved the VTR CDI module from the bike, it trigger nice sparks but ditched the control module.
I use dual tables since the rear cylinder likes a richer mixture
I run the Hybrid alpha-N blending from 2300 to 3100 rpm, this is why the VE tables are weird, the bike drives like a charm but does not make it's full power yet, I may work on the engine a bit before I turn up the boost
- Attachments
- VTR1000F 3.16 Dyno fuel.msq
- (25.17 KiB) Downloaded 70 times
