can not run engine smoothly
*At moment problem, we cann’t run engine smoothly as always fluctuation in “not crankingâ€. At beginning we try to keep the gap between sensor and gear more closer, but problem still exist. Do you have any experience or recommend us to do some investigation?
best regard chlin
- Attachments
- datalog200905051033.msl
- the 24 teeth trigger wheel datalog
- (25.66 KiB) Downloaded 79 times
- megasquirt200905030155.msq
- about 50CC engine msq file
- (25.33 KiB) Downloaded 70 times
Re: can not run engine smoothly
In order to set this up properly in the msq, we need to know: no_cylinders, 2 or 4 stroke, verify you have a 24 tooth wheel with 1 tooth missing.
because i just want mircosquirt to control inject fuel and i do not use the spark output by microsquirt,should i tie the spark output together?
and i also have other sensors on my engine,like MAP,TPS,CLT,MAT,EGO...
i have confused with this problem 2 month. best regard
chlin
- Attachments
- dual tach setting.msq
- dual tach setting
- (25.33 KiB) Downloaded 67 times
- single crank wheel setting.msq
- (25.34 KiB) Downloaded 71 times
Do not attach the 2 spark outputs, just leave them floating. Also set your cranking rpm to something reasonable like 300-400 rpm instead of 3000.
If the engine doesn't run smoothly, can you smooth it out by giving it more or less fuel ? Are there any air leaks ? I looked at your datalog and your MAP reading is way low (18 kPa) and there is very little variation in it, especially for a 1 cylinder engine, so I suspect it is not hooked up. The fuel pw is set at 6.5 ms and does not deviate, so the roughness is not because the fuel is jumping around. The rpm is following the wheel, the deltaT column shows the times in microsecs between every skip_teeth. These times are jumping around just like the rpm.
