No cranking/ Microsquirt could not read rpm
Base on the same engine, we face a problem when replace to Microsquirt; no cranking or not able to read rpm.
We also have checked using Tooth Analyzer and found that tooth wave were detected. However we can't read rpm on Megatune. We certainly not confuse in embeded code between two kind of .s19 files and two kind of cranking sensors.
Do you have any recomend I could check. Or problem caused by some setting parameter.
Re: No cranking/ Microaquit could not read rpm
Re: No cranking/ Microsquirt could not read rpm
- Engine Nissan VQ20 6 Cylinders
- Crank wheel is Hall sensor type, Crankshaft position sensor (CKPS/REF)
- No crank synch
- Ignition type --> we still use the signal from origianl Nissan ECU
- Monitor V2.89 and Monitor_v2.890.abs.s19 were performed
and also we attached two msq files, HCCI_part_two.msq is for Megasquirt and megasquirt200903311617.msq run on microsquirt.
Actualy Microsquirt were desired to controll 50cc-engine in our lab, but we couldn't detect the rpm. So we tried to test the microsquirt on Nissan engine instead using Megasquirt which achieved already.
- Attachments
- HCCI_part_two.msq
- Megasquirt
- (25.08 KiB) Downloaded 40 times
- megasquirt200903311617.msq
- Micorsquirt
- (25.09 KiB) Downloaded 47 times
This system shows the pulse signal every evolution. We tried to adjust Advanced Ignition Option>Trigger Wheel Teeth(teeth) and found detected in rpm. But rpm is still not correct.
What kind of this Tach signal? Is it reasonable to count it as Trigger wheel setting for my Tach signal as shown in the picture.
Your setup will allow you to use the trigger return starting option. This means you can set it up so that it fires on one edge of the tooth during cranking with no advance, so there is no timing error during cranking, which is important for a single cylinder engine, then after cranking it switches to the other edge and adds in normal table advance. But don't worry about this right now - it is just something to consider if you get a lot of lost synchs during cranking because the engine is very jerky from the explosions.
But the idle speed is the wrong value(up 16000rpm)and the real idle value is about 1800rpm.mabye i do not set up correctly.
banchat is my senior and he helps me to slove this problem and my english is poor,pardon me.
thx
best regard
chlin
- Attachments
- megasquirt200904081339.msq
- .msq file
- (25.06 KiB) Downloaded 44 times
But more important, I don't understand how it can be that the actual rpm is 1800. The deltaT is the raw time in microsecs between pulses of the wheel sensor - it is just the difference in times. I have never seen it be wrong.
Secondly, you have a lot of electrical noise getting into the wheel sensor signal. This can be seen by the Trigger+/- column. By the time you started the dialog it had already seen about 5000 extra pulses arrive. It counts up when a pulse comes in that is out of tolerance with the previous deltaT time, then it throws out this extra pulse if it only happens once and then the next pulse time is good. But then it can keep going like this. You might try changing the setting on the acc_synchk input from Always to Never check for synch or only check when no accel. See if either of these changes help any. Also, first check that there are no wires laying across spark plug cables.
The last question I have is does this work with megasquirt on this same engine, wired the same way, with the same msq except the minor changes needed in polarity and ECUType ? That is do you get correct rpm and no noise problems ?
because the actual engine speed is about 2000rpm,just like you said it is diploid .
and what should i have to regard?
what i mean is i know the value is double however i use the microsquirt.and i tune the other parameters to suit real engine speed.
this engine is used for supermilage that used injector to squirt fuel...
best regard
As far as what you can do with the present wheel, just ignore the real rpm and set up everything as if the rpm on the pc is the real rpm. So if you see 3000 rpm on the pc, then you adjust the ve bin for 3000 rpm.
