Knock sensing Code Update request
I am looking to try out the knock sensing algorithum on my motorbike. However the current settings only allow for <6000 RPM in the knock threshold table. And < 10000 RPM in the settings menu.
Can this be reset to something higher (15000 RPM?) My bike revs to 13500 RPM. Searching on the web I think a better result can be obtained by having the thresholds adjustable over load (MAP) aswell as speed, perhaps 4 MAP bins. Also OEM ecu's adjust for knock over the whole rev range, in areas where the engine is knock limited.
Can the signal also be averaged also only at a specific angle after a ignition input has fired? For example, only run the code for this function between 20deg and 60deg after ignition (calibratable). To get technical this could also then be cylinder specifc (sequencer!!) but probabily not nessicarry at first.
Cheers.
Re: Knock sensing Code Update request
I read more on the subject of conventional knock sensing after posting the message and it appears that the way that alot of the knock sensor detection algorithums work is something like this.
1. Use a broadband knock sensor
2. Adjust a bandpass filter to only allow frequencies at the knock frequency of the engine. (calculated from the bore diameter)
1b 2b. If the factory sensor is already tuned for that engine just use that input.
3. For each cylinder define a knock window in crankshaft degrees where the engine is likely to knock. This can be adjustable depending on RPM and load for maximum effect. The maximum knock sensor voltage is captured during this time.
4. Outside the window(s) the knock sensor voltage is averaged.
5. Compare the difference between the maximum and the average to calibrated values to determine knock intensity.
6. Take action depending on the intensity.
The problem I can see is that on multiple cylinder engines there is not much time between firings to average the knock values. Perhpas that's why V8's and some 6's have two knock sensors. However for a 4 cyl or less there should be plenty of time to look for knock and average the signal. Another strategy could be to average the signal in coast conditions where there is no knock.
There are others that use a dignital signal processor to analyse the frequency spectrum from the broadband knock sensor directly, however these are expensive and probabily not an option for mega/microsquirt.
Anyway. Can you make the changes to the range of the calibration values anyway so I can try the existing algorithum?
