2.883J code problem
- puntogt4
2.883J code problem
Try to run the engine, rpm arrive to 280 rpm but fuel pump don't go, no spark, nothing!
I double check all, try to put the 2.883j in MSII (before running whit extra code) same problem!!! what I wrong??
- puntogt4
here my .MSQ and logger file
- Attachments
- _B&G_MSII.msq
- My MSQ file
- (25.11 KiB) Downloaded 62 times
- cranking.xls
- When I try to run
- (11.03 KiB) Downloaded 61 times
- puntogt4
ok here the 1°
log is when i want run the engine, like MSII show the rpm but no cranking in megatune
On 2°
i disconnect the VR sensor and place it on my simulator ( is a 36-1 wheel + cam pulse drive by a DC motor)
Here very strange... i run the wheel before to get power to microsquirt fuel pump continues work and spark arrive! then stop the wheel wait stopping fuel pump and start again, nothing no spark no fuel pump ( this are show on 2° log)
sometime when i move the wheel by hand run-stop-run-stop, on the moment when i stop fuel start if i run again the wheel all work also at very low rpm
Can somebody help me to found were i wrong? configuration in megatune? i try to download more time the code but same result
- Attachments
- zxr750.msq
- (25.04 KiB) Downloaded 53 times
- cranking_microsquirt2.xls
- This when microsuirt found already the wheel run
- (21.84 KiB) Downloaded 52 times
- cranking_microsquirt1.xls
- this when i start normaly
- (30.39 KiB) Downloaded 51 times
- puntogt4
I reload again the file, test with my free wheel ad look more:
when the wheel stop sometime fuel punp go and if i run again the wheel
spark arrive, but inj. no.
the advance is at the same angle....
I'm not sure but the fuel pump start when the wheel stop in the midle of 2 toth.
For end i try to test the injctors (by using the option) and now am not able to go back again the microsquirt is still in repeat mode, to stop I have to reload again the code by ms2dl104
Here one log of test
Set the injector Start to 0% now - I don't think you can use 180%, I think it has to be less than about 70-80%, but make it 0 for now.
Try reversing the tach input polarity (rising edge to falling edge or vice versa).but leave the wiring. If this doesn't help, go back to what you had..
Try using the code I recently (yesterday I think) released in the Ignition Tuning section (----v2.883jt1) for geoffct. Datalog this run. You should also read the posts in this section to see if any of the problems are similar to yours and read how they were solved.
Don't worry about the fuel pump. If the ECU does not get synch within 2 sec it turns off, but will turn back on when you get synch.
When I get a chance, I will try your msq on my bench and see if I notice anything.
Your channel 2 ignition output was all wrong. This was caused by using trigger return for the cranking trigger. This is only for special wheels - you must use either trigger rise or calculated trigger. Because you have a 60 tooth wheel you have very accurate timing and can use calculated trigger even during cranking.
The ECU would not go into cranking mode. This was caused by the Injector Timing Delay of 180%. I set it to 0 and it cleared up the problem.
With those two changes, I got steady ignition outputs on the scope for both channels.
So make those two changes and you should see some improvement - it may even fire and run fine because your rpms were consistent, but one of the spark outputs was all wrong. I believe you were getting synch, now that I understand why the engine column was 1.
- puntogt4
He had the problem!
On the Ini file now I put "98" instead of "255" as the limit
For the cranking it was set in triggers return but only for test now is trigger rise....
Now the bike run very nici (but specially RUN
Only a little issue is when the engine stop, too low rpm or bad VE... if i try to run again the fuel pump don't star, i need to reset and run again...
many thanks again for your support
