(idea) Project recap: 8hp Kohler single cylinder engine (K181). 6psi supercharger. MicroSquirt running fuel and ignition. I've successfully gotten 37hp (10hp block) to the ground on alcohol garden tractor before using a carb. But alcohol has been ruled out. It's time to raise the bar and go EFI with a S/C.
I've seen the superbike down the page running on only the TPS, buts whats the minimum sensors that are needed to be used on in engine to assume accurate control of the engine (with Micro Squrit) and which ones can be simulated with the tables in Mega Tune?
It's mostly a space concern. With my little 8hp, the intake/throttle body is basically a 3/4" tube with a butterfly in it. I will be able to use a TPS, a remote MAP (connected with vaccuum tubing), a HAll or VR sensor for timing, an 02 sensor in the exhaust, and IAT sensor.
(I can probably get a coolant temp sensor in the head, but being air cooled, I'm afraid I'd overload or melt the thing with the head temps well above 500degrees at the end of a run. I could put it in the block close to the cylinder but then I don't know if it would warm up fast enough. Testing is in order I assume.)
Is there anything I will need to make room for? I think I've got it all covered. But I don't know... As far as I'm concerned. It never hurts to ask.
I know there are a few guys running 1-cylinders on here and the MegaSquirt forums, maybe a few suggestions could be kicked my way. I've seen one Kohler K301 running a Garrett Turbo and Megasquirt on the web, But have never seen him on here.
BTW: I've got my fuel system nailed down using a PICO 19lbs/hr injector, running on 30-35psi of fuel. (maybe less) I want to use the PICO style because it's only 1/2" the size of your standard Ford/GM injector. Also, my pump, regulator, fuel tank, and lines have been selected. As soon as I figure out the theory how to make the thing fire with only one cylinder (it doesn't exactly say "Do this " in the Mega-manual), I will be ordering parts! I also have to convince my wife I need to spend nearly $1000 on cool parts and stuff to make my little tractor do it's thing.
Edit: Also, no one around my area and in my club is goign this route. Plus I'm keeping it Top Secret to the guys I pull with. So the forums are the only place i have to spit out ideas. THANKS GUYS!
