I'm getting the "'DarkStar' Custom IAC Body for Jeep Stepper Motor Idle Air Controllers"No stepper IAC control: In order to make room for the dual ignition inputs and dual outputs, the ability to to control a stepper IAC was removed. PWM Idle valves, as well as on/off idle valves, can still be used.
http://www.diyautotune.com/catalog/cust ... -p-69.html
Does that mean it will not work if I use the "IAC valve from a Jeep 4.0l motor" (from DIYautotune description)?
